Originally posted by Sandy
Originally posted by Jimmy B
Thanks for all the good things to check...Just remember I was towing a 12 AB inflatable center console with a 40 hp Yamaha...My flowscan computer said I was burning 12gph on the starb eng and 9 gph on the port eng. I'm leaning toward my tach being out of cal. The boat ran great and started and idled fine.(No black smoke)
Was your original observation of 32 gal burned by one engine and 52 gal burned by the other based on the Floscan totalizer display only, or by gallons actually pumped to fully refill each tank at the end of the trip?
Particularly at low speeds over long time as when trolling, FloScans can sometimes be inaccurate , or the sensors can give inaccurate readings of actual fuel flow if air is entrained in the flow( filter gasket, loose clamp, spongy fuel line..) or trapped by the sensor if the fuel line is not kept uphill to the engine from the flow sensor.
An inexpensive photo tach is one of many ways to get a reality check of your tachometers' accuracy.
http://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html
