garmin 2006C loss of GPS signal - solved
Moderator
I've been having an issue with my 2006C, about 3 or 4 years old...
over the past few weeks, it would occasionally loose signal from the antena, usually for a few seconds. totally ransom, not linked to waves or wakes...
then yesterday it simply wouldn't acquire at all.. yellow warning staying no signal from antenna.
I'm going to check the wiring, connection, antenna for external damage. If not, is there a way to test the antenna to see if it needs to be replaced ? I'd hate to buy a new antenna jsut to find out it's the plotter itself...
Les, if you see this thread, do you carry compatible antenna for the 2006C ?
