hi,
i am pretty sure i have a gas tank leak. i have the boat stored in my driveway. occasionally smelled gas along side of boat a few weeks ago. at that time i checked the engine compartment, check the drain plug on the transom, only water dripping out.(plug had been removed). last night taking the garbage out the smell was stronger, i checked the drain plug again and gas was dripping out in a small stream. i placed a gas container underneath the drain plug. i am pretty convinced that the botton of the gas tank must be leaking and flowing towards the transom since i have the bow slightly raised.
the stream got lighter, by this morning there was a ocassional dripping but seemed to be water not gas.
i am trying to find out if the gas tank back then was made from alumininum or steel and also aprox gallons of gas it would hold (i think it takes somewhere between 24-35 gallons)
(so much for the new ashphalt driveway i had put in 2 years ago)
any help or suggestions is appreciated.
thanks again, john
thanks again, john
