Have crusader carbureted Gen 6 454 engine ( replaced old long engine with new Gen 6 long block we used al the old brackets with new components adding and electric fuel pump and Mallory distributor.
Engine stumbled at cruise of 3800 rpm after 45 minutes out of harbor then lost power. Went back to the slip replaced carburetor with rebuilt. Engine began to run again but only up to 2200 rpm. swapped carburetor with other motor same result. Replaced all ignition components, fuel pump, pulled valve covers looking for irregularities in rocker arm movement non found, all cylinders had compression 150 except 1 at 145 & 3 at 140, Checked inside distributor for loose or broken components none found. replaced breaker to main ignition voltage no change. at a loss for where to find the problem. Do any of those of you in this community have a suggestion what I can do next to identify the problem?
