genset question
greenstreak
How much gas does a kohler 5 kw genset use an hour? I know it depends on the load but I am trying to get an ideal. The boat I just purchased has one.
art
Art, not a direct answer to your question but for what it's worth; my 6.5KW burns 1 gal/hr at full load.
Based on direct experience, about .5 to .65 gal per hour.
http://www.kohlerpowersystems.com/pdfs/g2058.pdf Fuel burn table is on page 2...
thanks everyone for the info. That is not bad running the genset for 8 hrs using about 5 gal. I am sure just running the air wouldn't put a full load on the generator.
art
Just running the AC should not put a full load on the genset, but you should try to get about 75% on it, running it with a light load is not good for it.
When needed, I run my genny with both a/c units, water heater and battery charger just to be sure I am running close to half load. I haven't had an issue yet. When not in use you should run weekly or so with full load for about 30 minutes.
Not sure I agree with advice to run at full load for 30 minutes a week. I believe Westerbeke advises users to avoid full loading for extended periods of time. WB does recommend running a 75% to promote good spark plug life.
