Generally for water in any cylinders, pull the plugs, close off raw water inlet and turn over engine to dry out cylinders. squirt a little 2 cycle oil or marvel mystery oil to lube the rings and cylinder walls. clean or better, replace the plugs like Brucie said. Don't forget to turn water back on.
