Getting closer
Moderator
Only about 6 weeks until the cover comes off
You mean 6 weeks and a day until the last snow storm?
So I found out two years ago! This year I will wait for Hogan to pull his cover first.
I thought it was here I read something about that. Hopefully it doesn't happen again!
28 more days!
You first then I will gladly follow! I have a bunch of projects to jump on:
Painting the arch
reinstall the coolant tanks
replace coolant hoses
install underwater lights
reinstall dash yet again:)
Install new salon table
replace galley flooring
Wash wax
touch up bottom paint
launch
I think I need a couple of days to attack this list I may not get in until May this year NOT!
Sent my cushions out to be re-done, side curtains out to have smiles put in them. Need to install satellite dish and new Lenco trim tab actuators. Will replace all cooling hoses on both engines. Bring back all the booze I brought home. Wet sand from the rub rails up, wax entire boat. Start burning cheap diesel and enjoying being back on the boat.
OK, it's mostly new stuff, imported from Aruba...
Hogan who is doing the cushions for you? If you don't want to say send a PM. I'm very happy with the work I had done!
Allen you can install it yourself if you want. I installed mine not a big deal on our boats but not cheap either!
I am using Sandi, at Action Marine. She did my big cushion last year. She does very good work.
I'll install the dish myself. Not a big deal.
With streaming internet you may want to try a Roque Wave antenna that is if you use optimum so that you can access their WiFi I get pretty decent signal with my setup. Just food for thought.
I pick up an Optimum hotspot right at my slip on our laptops, and usually get one in Bowline the same way.
The underwater lights I bought at the show were delivered the other day I can hardly wait to go drill holes in my transom!
I'm hoping they are bright enough I think three should do the trick!
3.7 amps each???? That's a big drain on the batteries!
