Yes and no. The GPS worked for the survey but now has failed with a "DSC signal lost" or something error. After the survey another test run was done where this was observed and the GPS antenna was replaced. The condition is very intermittent at dock and constant at cruise which makes me suspect a loose connection somewhere.
The water temp was off at the survey and this was noted at that time. I have a call in to see what was done to address it. On the first run after I took delivery, the water temp and depth worked, but now neither do.
