Here we go again with another overheating issue.
My question is simple, Does the "RWP" (Raw Water Pump) provide a larger volume of water to the risers and heat exchanger cooling down the "FWC" (Fresh Water Coolant) at higher RPM's?
We'll my 1998, 454 7.4 VP doesn't keep the engine cool at high RPM's. I can run 5 to 8 MPH all day long but when I accelerate and run on plain for a minuet or so the temperature rises until the computer brings the engine done to the safe mode.
I have replaced the manifolds and risers, checked the flow and all seems clear the only thing left would be the RWP impeller? the circulation pump? or a blown head gasket? as for the BHG, there is no smoke, the oil looks good. so I have really ruled that out.
What else could be causing the engine NOT to be cooled down while under way at high RPMS?
Thanks all.
Thanks all.
