GPS Numbers?
Tanqueray
I'm sitting here playing with my new GPS Standard Horizon CP-180.
The Antenae is out on my enclosed front porch and certainly isn't moving.Yet I'm sitting here watching the screen and it's showing a reading of Speed Over Ground of 0.1 to 0.5 miles per hour. (fluctuates) Also my Course is constantly changing. How is it doing this when everything is stationary?
My guess is it is averaging positioning input from differing sets of satellites so speed is calculated from last calculated position with slight error to new calculated position with slightly different error.
It is displaying a course because of the disparity in calculated position, always last to next.
As you know you and the GPS are not moving, there is obviously no actual course the GPS can display , only between the change in erroneous position, however minute.
It can, however, display a reasonably accurate bearing to an entered waypoint from your present position, the farther away the more acccurate . (I.e., if you entered a waypoint only a few feet from present position the normal error in calculated position would not be able to over come this proximity to supply an accurate bearing, considering WAAS correction accuracy to "only" perhaps 3-9 meters or more.
I agree w/ Sandy.
his small error is also why you should not place an anchor alarm too tight. Theboat and anchor might be just fine, but the fix itself will wander a ( very ) little. If you set an alarm ring too small, you will keep hitting it...
( Not me. I didn't do it. I promise. )
Just read Sandy's reply....got the same headache from when i was in quantum physics....along with the same dull expression on my face...
My apologies ,m4003 . Inflicting migraine was certainly not my intent.
At least I didn't throw in Big Al's wild & crazy idea that nothing is inherently stationary anyway, only perceived to be moving or not relative to some other object moving in space. :D :D Yikes, now even I'm getting a headache!
Sit still. Dont be waving that thing around when you reach for more Scotch!
Until you understand it, don't use it, it will get you in trouble, if you really have to navigate.
This reminds me of my parent's elderly neighbours. They all live a few miles off the pavement if you know what I mean.
These folks were driving down the road paralleling the lakeshore holding their new fishfinder out the window of their pickup. Not being electronically astute enough to realize that it was in "Demo" mode, they stopped by to brag to my Dad how powerful and amazingly accurate these newfangled gadgets were. Just look at all the fish!!
Kev
Jim.....It's not a matter of knowing or not knowing how to use it. I just had a question about why the numbers are showing changes when everything is stationary......or did you miss that part?.....or are you one of the guys with no answer either but will in the next post advise me to take a Safe Boater's Course?
Get the antenna away from anything that might reflect the GPS signal. Its probably having trouble picking which signal to use.
You're probably reading satellites that are all in one direction and on the horizon. Get out from under the roof.
Makes sense to me......Now that I think about it I do remember seeing the Satellites being used all in a straight (almost) line on the Status Page. I guess it certainly won't hurt to try moving it outdoors. Geez...It sure is still cold out there though. lol...
Thanks for the suggestion. I'll try to let ya know later today and if not....tomorrow.
GPS can only show a course when you are moving. Your not moving so as others have stated you are measuring and plotting the error. Once you start to move, even slowly, that movement over comes the error floor and you get accurate readings. The failing of GPS to show a heading without the receiver being in motion is why you need a heading sensor to do radar overlay.
Also keep in mind that while you said nothing is moving the satellites are moving at a pretty high rate of speed!
Thanks for the input rommer ..... and that's precisely why what rbmitchell said makes sense. I'm gonna see if I can somehow move the antennae outside today without freezing out the inside of the house. Thanks again and I'll let you know.
GPS is good, but it's not absolute. Even outside it will drift a little.
Punch in a "go-to" at your current position, and then watch how much it actually moves from that point. I think you'll find it doesn't drift far.
A few months ago I set my handheld and set it a few inches from my console set. There was a consistent difference of several feet in the readout.
Some units have an "averaging" setting that you can adjust (usually in Setup). It should give you a better position when you're stopped, but the unit will be less responsive when you're running at speed.
