GPS Problem
ajschwab
We have a Raymarine Raynav 300 GPS Plotter connected to a surface(radar arch) mounted Raymarine Antenna. The Raynav 300 is then connectected to the Raymarine SL70RC Plus Series Radar Chart Plotter Display. We lose the fix repeatly and sometimes it comes back and sometimes it does not. Has anyone enclounterd the same problem and found a solution?
I had the same setup on my last boat. Does the Raynav loose fix or just the plotter or both at once? How are the Raynav and the plotter connected, Seatalk? NMEA?
Have you had the unit updated for the new WAAS satellites? They were changed last July. Most of the RayMarine units required a software upgrade which wss not available until late Sept. 2007.
The Raynav 300 is a real headache. In fact, I believe it is no longer sold by Raymarine. There is a fix for this problem. There are instructions in this forum several times during the past couple of years. You can do a search to get the information. I fixed mine a couple of years ago. It involves getting a Raystar 125 antenna and a seatalk junction box. Fix is not difficult. You would not believe how quick you get a fix after this install. And, not fix is not easily lost.
TO Shake and Bake. Both Units loose the fix at the same time.
first thing i'd check (beside the issue bob mentioned) would be the antenna cable to the GPS. I have a similar problem (garmin) the cable was chafing and gettting damaged resulting in occasional loss of signal.
What Pascal says . . .
Had the same problem, finally determined to be bad ground in GPS antenna cable.
Doesn't splice well -> replace.
