Haloing ?
Viking76
I was advised that I have haloing around my hull zinc plate. It looks like an irregular circular pattern loss of bottom paint around my hull zinc plate. This zinc hull plate was added approx 5 years ago and connected into the bonding system. I was told that I may have too many zincs. Can you have to many zincs? It was added because the shaft, rudder, and trim tab zincs barely last thru the season. Haloing? Cause? Fix?
I have never heard the term Haloing. However you may have stray current from a miswired dock pedestal to another boat near your boat. If you have the ability to measure stray current I would start there. The problem could also be on your boat with a DC wire laying in bilge water to bad connections on the bonding circuit. Also does your barrier coat contain copper or some other metal oxide in it?
I am thinking out loud.
I assume your boat is a Viking? Are you on a mooring ball, stand alone dock or a marina?
Are you always hooked up to AC power?
usually stray current. You will find alot of info online about proper zincing and measuring and looking for stray current sources. Haloing is a common term for bottom paint erroding near zincs.
