hatch plexi fell out
BOBD902313
I have a taylor hatch on my Sea Ray.
The smoked plexi keeps coming loose and falls out with resultant leaks.
This has happened before. I've tried 5200, but only lasted about 1 season (maybe).
Any ideas on an adhesive that will keep this plexi window in the frame?
5200 is not the bedding material to use. There are structural silicone adhesives which are specifically made for plexiglass (or polycarbonate--Lexan). Urethane adhesives may damage the surface of the plastic. As Flutterby suggests there are a number of plastic fabricators who will have the latest version. I believe that the current product is GE silicone sealant GEM-GE55. Also Dow 732 should work--but check it out with the experts. I used one product the first time, and then had to redo the lexan, because we got some leaking. Remember that the silicone floats the lexan, and you need small cork/rubber spacers between the frame and the plastic (we used 1/8" thick pieces of cork rubber gasket material to give an even bed). Leave the paper on the lexan until you are thru, cut back the paper on the side which will be the bottom, the amount of the frame. Mask the frame. Some of these structural adhesives are very strong. I got a small "dab" on a SS shroud, and 6 years later it was still there!
