Head Odor Prevention
mike, use anti freeze to run thru your raw water lines, all of them, you'll be fine.
Here's a simple way to keep odor down and keep your tank clean. After you have it pumped out flush 2-3 times w/ clean water. Then flush w/ about a 1/4 cup of powered tide (no bleach) and it really does the trick and is alot less costly. When you have it pumped again do the same thing - 1/4 cup per tank. No fuss no muss.
Having two dogs at home I keep a small squeeze bottle of "Natures Miracle" in the head and give a little squirt after a flush. Seems to work just fine, no odors.
