We bought our first boat recently, a beautiful 1979 Cruisers Yachts 288 Villa Vee. It is in incredible condition, has lived in a 3 sided boathouse most of its life, and appears to have been serviced regularly.
Our problems right now relate to the head, which is electric and has a 40 gallon holding tank. First,it doesn't smell too good. From reading 9 pages of head posts in this forum, I am thinking we may have permeated hoses...we'll check for that this weekend. Is changing out the sanitation hoses a DIY job? DH is quite handy, but he woudn't want to spend a whole day with his head in the head!
The second problem seems more serious. We had the holding tank pumped out the last time we were out, but forgot to put the deodorizer in (we won't do THAT again!). I put it in, and noticed behind the toilet was not too clean, so proceeded to wipe it down with Clorox Wipes. I cleaned off hoses, too. I did NOT bump or move either of the valves. When I flushed after cleaning the bowl (with a proper cleanser) my husband was outside and saw that it flushed directly into the lake instead of the holding tank! He tried the valves in every conceivable configuration, and it didn't make a difference, it all flushed to the lake, yikes. Could this be caused by a clogged valve? I have seen reference to duckbills(?) and Y valves while reading this forum. What exactly are the functions of these, and how do you clean them? Again, is this a DIY project?
If you have any thoughts on what else could be causing these problems or what we should do about them, we welcome your input. Thanks so much for your help on these smelly (and illegal!) problems.
Jan
Jan
