I am new to boating, just bought my first boat in Jan. As I use the boat small repair items keep presenting themselves the latest of which concerns the toilet. I have one of the very common Jabsco manual pump units manufactured in 2000. My problem is two-fold. First is that the pump is not pumping water (raw sea water) into the bowl as I understand it should. I have checked the valve to the bottom of the boat and is does not seem to be clogged or inoperative. My second problem is that fluid from the holding tank can flow back into the bowl after flushing. There does not seem to be any danger of it overflowing the bowl as it does not rise that high but I don't think this should happen. Is this normal? Is it possibly a bad "joker valve"? (Not quite sure what that is or what it's purpose is. I assume it is a one way valve designed to prevent this)
I have ordered a full rebuild kit from Boatfix in hopes that rebuilding it will cure these issues. Am I on the right track here? Do you think performing this rebuild will solve my problems? Thanks for your advice.
