Hi, heat exchanger on a 360 Chrysler 1/2 FWC. I want to take off the end plate and check for anything that could be fouling up the raw water stream (slight over-heating, working my way through the system piece by piece). If I remove the end plates am I correct in saying that only raw water will dump out and the fresh water is contained in the "bulb" on top? Sorry, thats not very technical....
Thanks for help.
Thanks for help.
