Hi all, I'm new here, and thought I'd jump right in with a longstanding problem. Here's the background.
I have an old 23 foot fiberglass cruiser. On its 2nd stern drive system and 4th engine. Boat came with MC 150 (1966) six cyl. The whole power pack was replaced with MC165 (not sure what year). Later, I believe an upgrade to the lower unit was made. I *think* it currently has a 1-R drive (if there's some way to verify the external hardware, I'd appreciate help with that). The 165 was removed, and upgraded to a Chevy 350 around 1984. This was a custom built, originally automotive engine that was built with marine grade gaskets, plugs and seals. Later, the exhaust manifolds were replaced with Stainless Marine units. At some point, the water pump was also removed and replaced with a crossover pipe (replaces circulating pump) from Stainless Marine. Eventually, that engine corroded internally and we replaced it with a rebuilt long block crate motor (I know, it's not marine, but the boat gets very little use, and it was just not worth it). I also realize that the gear ratio in the drive is not the right one for a 350, but we worked with propellers and found a good combination (a vented stainless unit) that gives appropriate top end RPM and pulls nicely. The boat is used a handful of times each season. It is operated in salt water, but I flush it after every run.
Here's the problem (and all the crazy questions I've been asking myself): The temperature creeps up when running steady at cruising RPM (2500 rpm). Also, it heats significantly when coming off plane and dropping RPM (keeping revs above 1200 or so, and some forward motion helps). It has always done this to some degree, but seems to have gotten worse over the years. I am not currently running a thermostat. I've changed the lower unit pump multiple times and it has no effect. Is the cooling crossover a bad idea? When running that kind of aftermarket product, is there some augmentation that must be done to compensate for the lack of water circulation? I'm not crazy about the water flow system in the sterndrive anyway...should I dispense with that and get a thru-hull with a crank-driven pump? Are my headers just clogged? If I wanted to attempt to establish something like a stock cooling system flow path in this motor, what is the simplest version of the standard combinations that would work using the Stainless exhaust manifolds? There are a hundred permutations of thermostat housings and routing of coolant lines. Is there a generic, aftermarket cooling system setup that is known to work well with SB Chevy? What about stern drive coolers? Would that help lower temps overall? Thanks much for your advice. By the way, I don't know actual temps, but temp gauge is showing hot, and the water coming out of the sterndrive is hot to the touch.
