I have heard that the "Bare Foot Mail Man" used to walk across the inlet many years ago but I didn't think Brian would Snow Mobile through at low tide.
The inlet is easy to use. Stay well inside the markers.
On the way back in, it is a good idea to line up with the Sea Buoy and the inlet.
There is a part of the Reef on the South side of the inlet that can be above water at low tide so be sure to stay between the markers.
There is a cut threw the north rock jetty on the north side of the inlet that looks like it is the entrance to the inlet when coming in at night(Disaster if you make that mistake). Line up with the Sea Buoy and you will be OK. The Buoy has a blinking white light.
The first time you go out through the inlet, run out to the buoy stop and look towards the inlet. you will see what I'm describing here.
One more thing, The inlet is Dredged once in a while. Check back on BE when the Dredge is in place.
