I have hit a rock that damaged the hull of the boat about 8 inches long .No water has cone in but pulling it out it is a bit soggy around 2 small areas .After that I have put water in the boat , it is sitting there for the paste 2 weeks and not leaking but as i say If you apply pressure its a bit soggy .Its impossible to get to it inside .Its under the build in fuel tank and aft berth .There is no one that can fixe it till this winter the boat .will only be in and out of the water for about 20 days .The area is only fiberglass .Any quick remedy that I could apply .There is always a small amount of water around that area inside .I was told since its solid fiberglass it would not cause damage to the boat .Is this true .Is my season finished
Louis
Louis
