Holding Tank Cleaned Out This Year
It does occur to me that there is a difference between those of us who keep our boats commissioned year round and those who don't. For those of us who use our boats constantly, you really don't want to rise "everything" out of the tank. Tanks stay sweet when they are maintained with the right bacteria and well aerated. Every time you dump, you want to keep enough "starter" bacteria in there to keep the science project going. You don't really want to completely start over and rinsing really does not help you. Boats that get used this way rarely stink.
However if a boat is going to be laid up for awhile, its typical that vent lines are not big enough to really exchange enough air to keep the science project going and can turn stanky. In that kind of situation, I do try to empty the tank and rinse it a few times with fresh water, but that means that I have to re-establish the science project to make sure it does not stink in getting going the next time.
If you can keep the system going, I think you are better for it. If you have to lay up, rinsing may actually have some merit. Some of this though is still just some kind of illogical fear of poop, not based on really having a valid reason for otherwise taking action.
my .02
CapnBrian,
I'm not trying to start a pissing contest (pun intended) here, I'm just trying to say that cleaning a holding tank to the point that "Now it is clean enough to drink out of..." is a little overboard.
It doesn't compare to waxing or changing oil. Rinse it after use, rinse it until the water is clear for end of season layup. That's all that's necessary.
I use Ron's handy dandy pump out system too.. It works a charm however on the last pumpout for this season I decided to have the wife flush fresh water down the toilet while I used the pump outside to the honey wagon.. I was amazed at the amount of brown water that came out!, this after completely pumping out and rinsing from the outside port only.. I've always just pumped from the outside dedicated port and then filled with water from this port and pumped out again, flushing fresh water down the toilet while pumping out yielded several tankfulls of brown water when it had been coming out clear by just rinsing from the pumpout port..
TIC, that was sort of my badly stated point, regardless of how good I thought I was flushing/spraying/sloshing fresh water around the tank, there was definitely still stuff hiding in there.
No problem, it was just a little humor, it wasn't that clean. Maybe I do have a fear of poop. I will have to discuss that with my therapist.[:-crazy]
A lot of good poop discussed above.
Originally posted by TIC
I use Ron's handy dandy pump out system too.. ............... yielded several tankfulls of brown water when it had been coming out clear by just rinsing from the pumpout port..
Someome once made fun of me for using clear hose on the output. Now we see why we use clear hose. ;)
BTW: That's good to know (running water through the head).
Originally posted by CapnBrian
....I bought a Tornado but didn't like the thought of cutting another big hole in my aluminum holding tank....
Aluminum holding tank?
An aluminum holding tank is something that will need to be dealt with sooner or later. Urine is very hard on aluminum and it will eventually develop leaks.
Add calgon to the tank. It keeps the crap (literally) from sticking to the plastic.
Yes, but it will kill any organic tank treatment products such as Odorloss or K.O.
Hey, that's why I want it so clean, its not the fear of poop but of corrosion!
Yep aluminum, surely not stainless, guess I better check for sure. This boat ownership experience just gets better and better. [:-banghead]
