Holding tank gauge quality - opinions please...
DLL
I used Snake River on my previous boat, but my 1987 Tolly 44 has other brands in it. Only one works.
My question is about the "other" gauges. If Snake River is running out of "parts", who are the other companies who make reliable units?
My aft head had two gauges. Forward and aft head gauges in the aft head. I think it would be better to put the gauge for the forward head IN the forward head. The only reason I can imagine for mounting it in the aft head is to keep the "info" about the holding tanks private. Can you think of any other reason?
To cover the hole in the cabinet in the aft head, we will use a sheet of 1/8 thick Mahogany. Pull the gauges out, put the sheet on, cut one new hole, install the single gauge, then put wallpaper over the wood.
All I need to do now is find a "proper" gauge for the forward head. It has a sheet of "foil" on the side of it, but when the two wires hanging loose are put against it, the gauge in the aft head does not "indicate" anything. My current thought is to replace the gauge in the back, run new wires up into forward head and install it in the cabinet. See any problems switching them?
Last and not least, is the fresh water tank. The gauge is inop and parts are missing, so I need to replace it. Again, only one tank will be on it. The wires seem to be intact.
The gauge is in the Galley. Wires appear to be intact, they are attached to "studs" that go through the fresh water tank. I guess any reliable gage will work. Suggestions?
If your tank are Poly (plastic) Raritan has a nice unit that will do up to 4 tanks. I use it on my Mainship to monitor 3 tanks all replacement Poly (plastic) tanks.
Give this guy a call and he'll give you the guidance you need and hook you up if you need new stuff.. He is extremely familiar with the type of system you have in place. One of the best customer service experiences I have had; hope he repeats it for you. No connection other than a very happy customer.
http://www.ferriellosales.com/default.php
George
The only one that I've found that works is Tank Tender. No electricity. It works off of air pressure and every time you check a level the system cleans itself. Old technology and has been around for years on high end boats. You replace an O ring for maintenance every 15 years. Accessibility for that is great and the job takes 2 minutes.
