Depends on the pod. Zeus your looking at props more in line with inboard. IPS had the props more mid-ship.
I hear IPS maneuvers way better than Zeus. Also more economical, but more vulnerable with forward facing props. Plus deeper draft!
I have owned 3 different propulsion systems out there. Bravo3, inboard and IPS.
My 34' with twin Bravo's was very manueverable as was my inboard.
Both were taken by wind and current and needed a careful Captain to understand and control.
IPS is un-comparable. I dock my current boat within inches, not feet.
Once you get used to a joystick and understand the amount of thrust and direction, docking is as simple as it gets. The biggest issue I have is sometimes making sure the joystick understands my direction because there is not much difference between some angles on the stick, so if i hit it to go reverse angle to port, i may be hitting it to go sideways to port and when docking this can be a big mistake!
