andy capt and Gami thankyou, based on the web site on shaft logs it looks like I need a 3/8 material.
Now have you guys ever experience something like this:
I was having a vibration on my starboard side and when I went to engine room I could see my shaft log wobble.
I was just bout to begin to remove prop and have it scanned. But over the weekend I went back and inspected the shaft log again and noticed that the jam nut was backed all the way off. I could not get it threaded at the time so I tightened up the log housing a bit and slowed the drip. While underway I noticed less vibration so went back in to engine room while my wife skippered the boat and no more wobble in the shaft log. So went back up top and before long I heard a screeching sound. So back into the engine room and noticed the shaft housing log tryng to turn on me and it was screeching like metal to metal. So I backed the housing back off and continued home. I cleaned threaded surface so I could get the jam nut back up to housing but even when tightening them both up I could turn the entire shaft log housing by hand?? So I backed the jam nut back off for time being and figured the packing material might be toast. While underway it did not feel real hot, but was warm. I do not have an excessive leak, but something is not right?? So for now I want to correct this, then run boat and check for vibration again before I pull prop.
