i think that Merc just has a history of not making things easy on owners. I'm not saying it's a conspiracy to help it's dealers but you got to wonder.
Isn't the Alpha one the only stern drive with the raw water pump in the outdrive ? which means that if you need to change the impeller, you got to haul the boat out and open the drive.
i had a volvo sterndrive 280 of similar vintage (mid 80s).. the raw water pump was mounted on the front of the engine, a little low but still accessible, and replacing the impeller was a 10 minute job. remove the cover, pull the impeller, new impeller on, new gasket and cover on. could be down out on the water if you had to.
fast forward 13 years, mercruisers 7.4 inboards. the pump was no longer bronze but plastic... it had to be removed to replace the impeller, which means the serpentine belt had to come off. then they place the water hose behind the pump, making it almost impossible to remove one of them. which means you had to disconnect the other side of the hose (on the strainer) and route out from under the engine.
dont' tell me ie woudl take %15k more to use a proven bronze pump like most engine use !!
how about boats that will sink if the fragile main bellow gets a hole ? how thoughtful is that ! in the 13 years i owned that old 85 vintage volvo, i dont' even remember how many times i pulled the drive and found the bellow filled with water ! tear, hole, brken clamp... never got a drop inside the boat ! Volvo used a very good set of seals and bearing in the bellhousing with a grease fitting inside the boat.
sorry... i dind't mean to turn this thread into a volvo vs merc debate but when i read things like it woudl cost %15k more to do it right.. it really gets to me when boaters accept lousy designs...
oh one more... steel bolts on manifolds... after 3 or 4 years, you have to cut them since the heads have decomposed... if their dealers know to replace them with SS.. why cant' they ? save $3 ?
then we hear things like.. it's under warranty so i dont care. yeah.. right... and you dont' pay for the warranty when you buy an engine ? do you like waiting 2 or 3 weeks for the dealer to do the warranty work ? manifold and impellers are not warranty itmes anyway... so you are paying that full hour of labor to replace a merc impeller instead of spending 10 mnutes of your own time.
