http://www.ebay.com/itm/like/221590221454?lpid=82Ok, now help me find the automatic trim tab for less than $200.
I want to add to my boat, but figure someone has one they never installed!
You sound like me.
I don't feel like paying $250 for the auto tab device.
Been holding out too.
Good luck.
On ebay you can create a search and it will email you as soon as someone puts an item with your search terms in it.
I have done this with a few boat items and it works out well.
If your sure it cannot be fixed with new wire terminal ends, make a Voltage Ladder back where the sender is, and any kind of a Meter that will reflect that Voltage.
Thanks. I will give it a try. There are two readouts Deg Down and % Down. The Deg Down numbers are blurred out...like sun exposure on an led... but the % Down does not work at all. That part might be caused by a bad connection. I'll check it out.
Yes I have. They were no help. Said to buy the new style indicators that have everything on the rocker switch. That would leave me with lots of new holes on the dash.
I just pulled the bad indicator and sprayed the contacts with tuner cleaner with no joy. It is one of those flat plugs with 6 or 8 wires in a row.
