it has a Hynautic steering system which is powered by the helm (wheel) unit itself. As you turn the wheel, it turns the shaft taht the wheel is ounted to which goes into the pump and distributes the oil as needed
the helm unit is actually a pump which sends fluid one way or another to the cylinders. If you have an autopilot, it has an electric hydraulic pump, mounted in the system that does work.
two important things to check with Hynautic is the fluid level in the reservoir (usually mounted in the ER) and the air pressure (around 20/25PSI). both fluid and air can be added to the reservoir. It's always a good idea to carry some spare fluid on board, either the $$$ hynautic stuff or ATF which hynautic approves (although steering efforts maybe a little heavier).
There is no tank...the resevoir is the helm. There is a cap on the top of the helm, that is where the oil is added. There is also no high pressure in this system, it is a revolume system...oil is pumped when the wheel is turned.
no tank on some, on a 3607 has a small one with 20/25 psi of air in it, can't speak for other boats but mine is under the aft queen bed to stbd.and get spare line, fittings i used it first time out.
I have a 1987 28 Voyager and my tank is in the engine room right in the center of the transom.
The gauge is mounted on top of the tank. FYI, I always carry a bicycle pump with me just in case I lose pressure. Very simple to pump it up.
