If the boat has Bennett adjustable trim tabs, used correctly to optimize performance at various speeds and attitudes and sea conditions, I really doubt any new attached "foil"/wing on the lower unit will help enough to make it at all worthwhile.
If you switch from 3 to a 4 blade prop, and all other prop characteristics remain the same, and present prop was optimum size , you would want to go down in pitch about an inch I believe to compensate for the add'l blade drag.
