Identify water hose fittings help.
estame6
1988 30 foot Sea Ray. Need to replace water connection between a cold water tee to the hot water heater. Approx 12 inches long with fittings no one can identifiy including our local Sea ay dealer. All other similar Sea Rays in the club has same fittings. Is there a supplier anywhere that I can check with? Thanks.
If I remember correctly, those fittings are very hard to come by. I would suggest replacing with a newer style that you can get anywhere.
Thanks. I can tell you for a fact that they are very hard to come by.
I thought with the number of 30 foot Sea Ray's around that were built
in the 80's someone would know of a supply. To start replacing all my
fittings because I can't find one compression fitting seems futile.
Maybe someone reading this and had froze a pipe or two has a suggestion.
Thanks again...
The older Sea Rays with the grey water lines are 1/2 inch. The newer Sea Rays use a metric size line that is 15mm. Comes in red or blue. You can still easily purchase all types of fittings for both sizes.......and also get an adaptor fitting to connect between the two sizes.
Check with Boat Fix or your local marine supply store....they are made by Sea Tech.
