So I was having this issue with my sbc 5.7. I wasn't reaching WOT or even close to it. The boat would not even get on plane. So another full tune up and still not going anywhere. I was thinking there must be a serious problem with the engine. I always read on here about making sure to have a clean bottom and running gear, but didn't think it could cause that much loss of power/speed. Hauled it out and pressure washed, sanded and antifouled the drive and trim tabs. The hull was pretty clean. Tons of barnacles on the running gear though. So, dropped her in this morning and she jumped right up on plane. What a relief... The moral to the story is... Never assume that it couldn't be something so simple/stupid. There is a reason people here give advice. I am a believer now.
Okay so... That one day I put it back in it seemed to be good. It was a quick ride, but she seemed really good. A week later, I go out fishing and she's running bad again. wont get up on plane. Bottom and running gear still clean. I'm wondering about the exhaust flappers... I had put some new aftermarket rubber flappers in at the beginning of this season. Let's say they are not "flapping", maybe stuck closed... Do you think this would cause the loss of power? I would think if it was holding back the exhaust, the engine would start getting hot, but she doesn't. Took her out today and she's still the same, doesn't run well over 2200 rpm, at one point, if I throttled really slow, I hit 3000 rpm and she planed. But, as I tried to trim or use the trim tabs she popped through the carb,Electrical problem? I am really getting disappointed at this point. Oh, one other thing, A new SEI outdrive...Has anyone had a bad experience with these? It was the right ratio for the engine.
Going to do another compression test after work tomorrow, I will post the results.
Thanks all,
Richard
Thanks all,
Richard
