It's either the E35 pump or the P101 (Crusader number 40050) pump. I'm not sure when they switched from one to the other. Both were made by Sherwood. My 93's have the P101. I believe the impeller is a 10615K. I've bought enough of them I ought to remember but that's just from memory so you'd want to double check it.
Does the pump look like a "u shape"? i.e. do the inlet and outlet point in the same direction? That's the E35. Or is it straight through, with the inlet and outlet exactly opposite one another, pointing in opposite directions? That is the P101. Once you know which one you have it will be easy enough to Google which impeller you need. The Crusader number should be on there, a 5 digit number.
I keep a link to this catalog from Sherwood Pump since it lists all the part numbers for their pumps, has pictures, etc. They also list them by engine manufacturer.
For some reason when you go to many marine part vendor web sites they will only show you the E35 pump and parts, even though the newer XL series engines don't use that one.
