Inflatable repair
wciparchia
Looking for repair service for my Achilles hard bottom, has a leak, anyone know of any in the area ?
There is a place in Old Saybrook, called "Sound Inflatables". I'm not sure if there is any place closer.
There use to be a place in Port Jefferson;
Port Inflatables tel.: 631 473-7177
I used them about 5 years ago, I'm not sure if they are still there.
If you have a repair kit and the leak is easily accessed, I'll recommend DIY. It isn't very difficult. If it is a very slow leak the worst of it will be locating it using soapy water. A thorough cleaning and inspection will usually give you a good idea where the leak is.
As long as this is Hypalon, acetone can be used to remove stubborn stains. Next a bleach gel. Once the bleach is cleaned off plenty of soap and water.
