I plan to change the fluid in my duoprop outdrive. In order to remove the props I ordered a volvo prop wrench set. The directions call for the props to be torqued to 45 lbs for the front and 50 lbs for the rear. My new prop socket for the front prop will not fit a torque wrench. One marine shop told a dock neighbor, who called because he wants to change the fluid on his houseboat duo drives, that using a torque wrench was not necessary that they just need to be tight. I am waiting for a call back from the shop where I purchased the boat but thought I would see if anyone has had this experience. I know I can modify the new socket to use with a torque wrench but don't want to if not necessary. Thanks for your thoughts.
