Hello all.
Want to confirm I am doing this right… just installed both heads and the intake manifold on my 1997 merc 5.7L and need to now install the distributor from fresh since the crankshaft was turned with it out.
So to install the distributor, I need to find TDC on cylinder 1 by removing plug 1 and when I feel compression build, stick a long straw in the cylinder hole to determine when the piston is at the top of its stroke. Once there, find the line on my harmonic balancer and align it to the 0 degree mark on my timing chain cover. This is TDC, correct?
Now, I did scribe a mark prior to pulling the distributor so I have a rough sense of where the housing should be. Bottom line is when I match up the scribed marks, I need to make sure my distributor shaft is pointing at the number 1 wire contact the the cap, correct?
Just want to confirm before I attempt on Tuesday.
Anything to be really careful to avoid doing here?
--Rick
--Rick
