Insurance Question
mcarrigan
For the past 7 years, my father and I have co-owned a '98 32ft express cruiser and split the costs. Bills were sent to him and I paid half. He no longer wants the boat, so I've taken over all the bills. After looking over the insurance policy, I noticed an endorsement for an "automatic fire extinguisher requirement". I do not have an automatic fire suppression system in the engine room on this boat. My father did not know what that was and basically ignored it. I want to get that endorsement removed, and I'm assuming my premiums will go up. The question I have is could the insurance company bill me for the lost premium for the past 7 years? Also, do most boats have some type of automatic system?
install one!!! simple, inexpensive and there is a reason why insurers give a discount. All my boats have had an automatic system, it's a no brainer.
and if you don't have one, put a fume detector as well! (assuming you have a gas boat)
that' no brainer nr 2 of boat ownership.
Just get a rate quote from a different insurance carrier to see the cost without one? I'd also install it.
You will face two potential problems if you don't install what I would call mandatory equipment. If you ask to have the policy changed they may insist on a new Survey and at the same time deny your request. They will probably give you a short time period to come into compliance. With insurance there is no bending the rules by the insured. I do realize you are trying to do the correct thing by asking but it will raise red flags. In my opinion follow Pascals opinion about the detectors as well.
The problem with uncontrolled boat fires may not be the loss of your vessel but others docked near you or even on the hard when stored.
I'd do what Pascal suggests and install one PDQ. Will save you money and headaches in the long run. Did the boat have one originally? I've never seen a cruiser that new not have one.
It was standard equipment on most boats back in the 1980's. I'll bet it's there, but may need to have the bottle checked and verified. They used to use Halon which has been replaced. Get the model numbers off the bottle and call the manufacturer. Sometimes they'll replace it on an exchange basis for about half of a what a new bottle costs.
On your dashboard, you should have a green light that indicates the system is charged and ready to discharge. If the light is out, then it's either discharged the bottle or there is a short in the wiring somewhere.
I don't agree that an automatic fire extinguishing equiptment was standard in the 80's or any other time. But it is an excellent idea, and I have installed it in many of my boats. I suspect in the long run, it will cost less for the equiptment than the extra premium over the years.
I don't understand why you don't have a very basic piece of safety equipment.
My 1987 Chris came from the factory with a Halon system.
When Halon was outlawed I changed to FM-200.
Just the piece of mind of having the sytem ready to go justifies the cost.
As said above you could possibly open a can of worms.
Good luck, I hope it all turns out well.
Abouttime
My 2001 cruiser came standard with an automatic system. How long do these systems stay charged. Can the units be refilled or serviced?
If you ever want to run for public office, or need to be appointed to a cabinet position, you'd better 'fess up to your insurance agent and pay the difference in preimiums over the last 7 years.
I've often wrestled with situations like this, and I've found that I usually already know what the right thing to do is. I think you do, too.
It definitely does not have one installed. I believe OMC may have owned Chris Craft in '98 and they were probably cutting corners. This boat is the definition of "bubble boat" that I have read about on this forum. I will look into having one installed. I'm already having the drives pulled, sand blasted, painted and a mercathode system installed this winter since the drives are corroding. I can have them install the fire suppression system also. It's a lot more painful now that I'm paying 100% of the bills. Thanks for the recommendations.
it's really a DIY project, unless you find pleasure in the pain of paying $90 an hour at the yard... see the above link, figure out the approx. volume of your engine bay, i'd guess about 200 cuft, find room on the bulkhead (do NOT mount on the hatch), and mount it.
then run the wire to the helm and hook up the warnign light.
if you have the yard do it, they're going to bill you 3 or 4 hours of labor plus full list (and some) on the bottle
DIY unless you want to spend about a grand for a 300 dollar project.
I would just get in compliance with the policy. You really don't owe them anything for the past as you were actually paying them premiums without having any coverage, a good deal for them.
My understanding with the Halon auto system installed AND maintained you can get away with less portable bottles, IF the system has a current signoff, or whatever you call it.
If the system is installed, but not periodically checked as scheduled, then you just assume it's not installed and carry the normally required portables.
The question is, does the insurance company required the inspections.
while legal, i can't imagine anyone not having extra handhelds having installed an automatic system! bad idea.
Paying premiums without any coverage????? I don't get it unless you assume that a claim would have been denied as the boat was not as listed?
I think that my engine room is about 10 ft. wide x 10ft. long and about 4 ft. high. Am I correct to assume that I would need about 400 sq. ft. unit?
