Interesting way
jrekemeyer
Interesting way to gain come clearance under a low bridge.
(Since the interest is here, here's the full sequence)
I hope that line holding up the weights is triple redundant.
Just goes to show you how resourceful us boaters are.
We have a couple of low bridges here in Ft. Myers. I saw one sailboat tie the top of the mast to a trawler and crank in over to 45 degrees.
By the way, what was the size setting for the photo you posted here? I'm just learning to upload pictures to this forum.
I use an applet from Microsoft's "Power Toys for XP" called "Image Sizer". Best of all it's free. After the install, when you right click on an image file you will get a new menu "resize image". Just click on that and you get a pop-up that will ask what size you want. I select 640x480. The applet will make a resized copy and rename it with small, medium or large as part of the original name. (640x480 = small) It's simple and easy to use.
It's only 512K in size, so if you want to download it go to this link. It's in there with a bunch of other goodies you may want to check out. http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
That can't be good for the rigging, that's a lot of weight pulling a single point at the top of the mast.
I don't think so. If I see it correctly, the actual load is on the on the base of the hull, quite possibly on the keel depending on how the structure is linked together.
That's the way I see it. I don't know, that doesn't strike me as idiocy. I think that was probably some pretty experienced people handling that maneuver.
It looks clever & resourceful to me, & similar to fairly common practice for sailboats' ungrounding procedure when circumstances allow. That said , I'm a little surprised the boat retained confident steerage with potential side drag from the bags. I would have expected to see a line to a forward boat to help avoid surprises in that regard , but the crew of that yacht may well have plenty of experience with this manuever and knew well what to expect. Slick pic.
Then again, perhaps they were just trying to get loose from the bridge......
we used to do the same thing to get pulled off thr bottom when grounded
Did he get stuck first and then rig the weights or was this the plan from the beginning? What is holding the weights away from the hull. If you rigged while the mast was vertical, they would just hang down alongside the mast. You would have to push them away from the boat to make it heel over like that.
Did some digging, and came up with this caption.
"This boat came in last night at Vero Beach. It has an 80' mast and 7'10" draft. Each water bag weighs 2000# It's been coming down the ICW. What a treat to watch the crew execute this maneuver."
Looks like a plan from the beginning , using perhaps lift bags (or drogues) with reverse purpose. If they were attached to the halyards and dropped to one side to fill, then the halyard slack winched in, I think the boat would gradually heel controllably taking the filled ballast lever bags farther from the hull to the limit of the calculated-length horizontal stabilizing leash-lines, also seen in the pic. That perfectly controls the amount of horizontal leverage arm distance and list ( vs.and equal to the keel weight times it's center of gravity horizontal distance from plumb) keeping the mast tip at a calculated or observed safety margin below the bottom of the bridge, and the backup safety element is the bags would lose effective leverage weight if they lower enough to submerge and have their downward force tend to neutralize by seawater displacement pressure. Pretty elegant, in an ungainly sorta way.
