Ok guys,
Looking for recommendations on whether to make the drastic decision to remove and rebuild that Roschester Quadrajet carb.
Symptons: cold start works great, take boat for a 20+ minute cruise around the sound, then when I slow down or back to idle, that's where the trouble starts: engine stalls when give it more gas from idle. it restarts ok, after a few pump, but switching to gear will stall it again.
Let the engine sit for half hour or so, the same cycle of events would repeat (i.e. works fine at the begining then stall later on ).
Based on my research and analysis, I Think it is a symptom of the carburator flooding and may need rebuild, however I am not sure if there any other troubleshooting steps you guys would recommend before I take this route.
Here are what I have done so far for troubleshooting this:
1. Setup is twin 305s with Divorced choke with single tank (This eliminate fuel issue since other engine is fine)
2. At startup, verified that choke plate is closed, then opens up when engine is warming ( This eliminates possible stuck choke or defective choke pull-off)
3. retrieve and inspect both idle screws and both are in sharp and pointy state. Even replaced with new ones that yielded
same results. ( switched back to the old ones )
4. Inspected fuel canister and no presence of water and/or dirt.
The only task that I haven't checked is the fuel return line, and I am not if a clogged line would show this behaviour.
If you think it's worth testing the fuel return line, how would I go on testing it?
Any pointers would be appreciated, as I am trying to cover all corners with this drastic decision to rebuilt.
Thanks all!
Thanks all!
