I let the air cycle thru the ice maker a few times.
So here is the process.
1) Drain fresh water tank.
2) Drain hot water heater (hook up a hose to drain valve on it, run it outside and blow air thru it)
3) Close hot water heater drain.
4) Turn on ice maker, put bar in down position to make ice. Leave on.
5) No blow air thru every hto and cold outlet (Kitchen sink, Shower, Head Sink, transom short, washdowns, flush toilet)
6) Open up screen filter before fresh water pump and vacuum water out.
7) Open ice maker, you will see it made some ice which is the water left in the hose which is now replaced with air. You don't need to worry if water is left in ice maker tray since it is designed to handle frozen water, but there probably is nothing there if it cycled a few times.
8) Check water heater again to see if any water trapped in there, blow it out again thru drain.
9) FLush pink down toilet, Run macerator.
10) Pour pink in all drains including scuppers and bilge hoses.
11) Vacuum out sump pump drain.
