This thing has always been an issue. 3/4 of the time it doesn't work and trips the breaker. This has been ongoing since 1992. I got a new electric unit under warranty. Seemed better but still tripped the breaker. I then thought that the wire was a size too small and replaced it with larger wire. It was better but did not fix it. I installed a battery next to the head to eliminate the voltage drop. It helped somewhat. This year I put in a rebuild kit for it. I think its working better; only time will tell.
My question is the joker valve. The boat did not originally come with one. The rebuild kit did. Should I install it or leave it out? I would rather do it before the start of the season since things are clean.
