My Jabsco manual toilet refuses to stay primed. I may be able to get a few uses out of the toilet and for whatever reason, it will lose its prime. I then pull the hose off to the bowl and put my finger over the outlet (connects hand pump to bowl) for the hose and carefully regain prime.
I have played with using/not using the switch for dry pumps and regular pumps. Doesn't seem to matter. If I run the bowl dry, it will for sure lose prime. However, as mentioned, sometimes it works, sometimes it doesn't. Why?
