JET DRIVE ?
I have an option on a Boston Whaler jet drive.
What are the pros/cons of jet drive vs. outboard
vs. I/O ?
I did not know Boston Whaler ever made a jet drive. Are you talking the propless outboard type or an inboard connected to a jet pump, or an actual jet engine?
The pros are that you don't have a prop so you can run in shallower water at high speed. Usually a foot or so. The cons are that you need a 25% increase in horsepower to maintain similar performance (or something like that). If you are in shallow areas, it can be a plus. If you run it slow through really shallow areas is like running a vacuum cleaner over the bottom and it will suck small rocks and sand into and through the vanes. This takes it's toll and will cause the jet to lose efficiency over time or fail completely. The advantage is best when you have a very flat bottom or super shallow "V" to reap the benefits of the jet. The Whaler might be OK, I'm not familiar with their bottom.
There are a lot of jet boats on the Snake river. It's primarily for running the shallow water. If you NEED shallow water performance I'd definitely get the jet. If you have an option and don't need to boat where it's shallow, get the prop.
Because the jet sucks up debris in shallow water, my SeaDoo jet boat came with instructions to stay in at least 3 feet. When I sold the jet and bought a slower boat (did not need to run 60 mph), I went to a power catamaran with an outboard. It gets me shallow enough.
At slow speed, a jet boat is more difficult to maneuver. At idle the drive is still turning. Because I had two engines and special low speed steering on my jet, it was easier to handle at low speed.
It is also a lot harder to get the ski rope out of a jet drive (under the boat) than to raise the prop and untangle.
For me, the outboard makes more sense.
Make sure the unit is easy to clean out. Eel grass in Barnegat Bay NJ and sea grass in Key West will stop the jet drive easily and for sure. If you have to get out and get under you will find more than your spirits dampened.
i seem to recall that little boston whaler jet drive was really small and not up to the standard of BW. i also remember that they built this boat back in the late 80s or early 90s didnt they?
ok, so early 90s...and they made a couple of different size rages. i have only seen the 14' version and recall being unimpressed - just as i am with most if not all of the jet boats (yamaha, seadoo etc). Just my opinion....
You are speaking of a Boston Whaler "Rage". Boat was lots of fun, when it ran and when the engine did not overheat. Now days you see most of them sitting on trailers for sale.
Actually, the Rage is not a bad boat at all, we owned one for a few years, and just sold it...
the ones to stay away from are the 94-97-ish with the OMC set up...
we had zero problems with our Yamaha set up in our 92, ...the final few years of the rage/late ninties, used mercruiser, and I have not had firsthand experience with those...
Ours was a great boat, solid hull, a little rougher ride in chop, but a lot of fun...the only reason we sold it is that we have a 2-stroke restricted lake we want to fish near our home, and moved to a similar sized boat with a 4 stroke outboard...
Our rage was every bit a whaler, with platform, scuppers, etc...absolutley no complaints.
I have owned a Rage and had a great deal of fun with it. it was our first boat and I thought it would be easier and safer than dealing with an outboard and a prop. We had a 15" w/the OMC setup. It did suck up mud and grass and would overheat. We dragged it to FL and the sea weed was just to much trouble to deal with. It was not bad as a starter boat, solid hull, good engine, and very quick especially for the size of that boat on the water.
Having said this I would recommend a I/O or outboard. I also would recommend a bit larger boat as it will not be that much more work involved.
ok, i will defer to first hand knowledge on this issue...but werent they basically flat bottomed hulls with a litle v in the bow - not even trihull.
yes, they have very little deadrise, and can ride a little rough, depending on wave frequency, but I don't know of a boat that is 14-15ft long that wouldn't ride rough in chop... The entry of the bow is not too bad, but it does flatten near the intake grate, as most all jet boats will, even our little 245 CC is pretty flat for deadrise... the intake grate on the whaler is about two thirds back on the hull...
you'll appreciate that there is less vibration from a jet drive over a traditional inboard. but the jet drive is not as efficient in its use of horse power. bottom line for the same horsepower an out board or i/o will move the boat faster than a jet drive. it is also more costly to maintain a jet over an inboard if you keep the boat in the water.
I appreciate all the feedback.
Some more specifics:
The boat in question is a '97 15-footer with a
175 horse Mercury Sport Jet (according to the ad).
I noticed on the Boston Whaler website that the only motor available now, for the 15's, is a 60 horse outboard. They haven't made the inboard jet for a while. I was wondering if maybe they decided that the "big" inboard was too heavy for such a small hull. Obviously they quit making them for SOME reason.
for vic33004: Why is a jet more costly to maintain ?
for Kastlercreative: Why stay away from '94-'97ish OMC ?
P'Head: Check out Continuouswave dot com. That's the Whaler site. You can find out everything you need to know about Whalers there. Enjoy, mon.
Regarding OMC, at least in this neck of the woods nobody will work on them, and getting parts is nearly impossible... I would not be afraid of the merc 175 sport jet, though some had electrical issues with faulty components, not sure of the details though, but if anything was wrong, you'd think it would show up by now...
I would think BW quit making them, just due to demand, and with the entry of all the other jet boats in the market, I would presume they went back to their roots...
The hulls were contructed the same way...We had zero rattles/creaks/flexing in ours it was a VERY, VERY solid boat and I'll be curious how it stacks up to the scout we just picked up (If this global warming of 8 degrees at night stops!)
here is kind of a fuzzy pick of the one we just sold...
Good luck with your decision, you may also note, the BW is probably the only boat that size you'll find with a swim platform and ladder stock...
