ARRRGGGGHHHH!!!!
Why does everybody think the joker valve is supposed to keep water in the toilet bowl???? [:-banghead] [:-banghead]
The joker valve is a one-way check valve that stops water from returning to the toilet bowl after flushing the toilet, such as when there's a partial clog in the line downstream from the toilet.
In the case of manual toilets, the joker valve works in concert with the flapper valve to direct the flow of water, and other stuff, out of the toilet.
Sometimes, when the joker valve is new - and only sometimes - it will hold water in the bowl after flushing - temporarily.
But that isn't its job, and this added benefit after replacing the joker valve won't last very long.
Marine toilets don't normally keep water in the bowl; they aren't designed for that purpose. As they must be used in all different onboard applications, many of which don't want water to be retained in the bowl, they are designed not to keep water in the bowl between flushes.
Picture yourself being on a boat out in the ocean, bouncing around during a storm, with the water from the toilet bowl sloshing out, all over your brand new teak parquet decking in the head, as an example...
The only sure way to keep water in the bowl between flushes, is to run the discharge hose from the toilet upwards - higher than the top of the bowl - to a vented loop fitting. Then the hose runs back down, to your holding tank, overboard, to a treatment system, or wherever the final destination might be. And that's the only way!
Now, repeat after me: JOKER VALVES DO NOT KEEP WATER IN THE BOWL BETWEEN FLUSHES !!!
---- rant over
