Kohler Genny Part Check
Looking to service my new to me Kohler Diesel Genny. Model is 9EOZD
List of parts I have so far and numbers is below. I noticed none of these part #'s are in genny now, looks like last service was all generic parts. Can anyone help validate these part #'s and tell me if there are good cross reference parts I can use. Not sure I like what's in there as fuel filter looks like a no name and the oil filter is some Japanese filter.
Genny Seconday 229715
Genny Primary R20TUL
Genny Heat Exch Anode 260085
Genny Oil (what weight oil is best?)
Genny Oil Filter 229678
Genny Impeller 229826
Thanks!
Thanks, I think I had that.
I was also interested in cross part #'s like Fram for oil filter, etc.
But I can order Kohler.
Maybe try ( decimal replaced by DOT + spaces):
http://www.atlantismarine DOT co.uk/Images/User//File/tp6270.pdf ( which you already have according to your April 2013 THT post, but refer to p. 21)
....leading for engine variation # 1 to cross-referenced Sierra oil filter 237824, :
http://www.amazon DOT com/Sierra-International-Filter-Oil-Kohler-Gm47465/dp/B006WQHWNE
or http://www.colburnpower DOT com/catalogsearch/result/?q=Gm47465&x=0&y=0
...engine variation #2:
http://www.amazon DOT com/Sierra-International-Filter-Oil-Kohler-229678/dp/B006WQHUUE/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1413682148&sr=1-2-catcorr&keywords=kohler+229678
or http://www.colburnpower DOT com/catalogsearch/result/?q=229678&x=0&y=0
or engine variation # 3: http://www.colburnpower DOT com/element-lube-oil.html for Kohler #250952 element.
Then ...,
# GM32359 Fuel filter for var. #1 on manual p. 39 :
http://www.colburnpower DOT com/catalogsearch/result/?q=GM32359&x=0&y=0
....or fuel element #GM10979 for var. # 2 & #3 on manual p. 40:
http://seafarerstore.3dcartstores DOT com/Kohler-229715-Fuel-Filter-Replaces-GM10979_p_35.html
Colburn Power and the Seafarerstore seems to have pretty good prices but I have no other knowledge about those sites. .
You can check for the other parts you list.
