Hello..
I have found that my power steering actuator has pinched the hydraulic hose that runs from the power steering cooler to the actuator thus, causing the hose to leak.
My question is... Do you think I can just splice the line with a copper tube? Then use some s.s. hose clamps or should I purchase the new hydraulic line ($90)?? I am concerned about the splice due to the amount of pressure that is in the system. But again the hose on secured by a hose clamp at the power steering cooler.
Thanks for the help!
