Cap-A-Radiator across from the Dunkin' Donuts on on Route 109 (Fulton St.) in Farmingdale. It's a little bit west of Main Street on the south side of 109.
Billy the owner is a great guy. Very honest and knows his stuff.
If that doesn't work for you I've been happy with LENCO rb2@gr5t 690D Albany Avenue Amityville 631-842-4049.
Heat Exchanger manufacturing and repair is their business.
If that doesn't work for you I've been very happy with Lenco at 690D Albany Avenue
Amityville 631-842-4049. Manufacturing and repair of heat exchangers is their business
Let us know if they are willing to do it and how it holds up. I ended up with a leaking tube in one of mine last year so that all the antifreeze leaked out into the exchanged and went out with the raw water. I called a radiator shop to see if they could just plug the leaking tube on both sides and they didn't want to do it. He said if one tube was leaking and they fixed it, others would leak as well. My mechanic used some kind of epoxy to plug the bad tube and it's been fine since. The heat exchanger is expensive so it was worth a shot.
