Leaky Shower Faucet Service
RiskyBusiness
The shower faucet in my 2004 360 Sport Sedan has developed a leak, It's coming from the handle of the single lever control arm - so I thought I might try and take it apart to service any washers or springs that are in it.
I found the set screw on the single lever arm and took it off - but the arm does not seem to come off. Anybody worked on one of these before have any hints?
Also - does anybody have any idea who made the shower, head and galley faucets for Carver?
Originally posted by RiskyBusiness
If you call Carver Yachts and talk to Rich Brown I bet he can tell you. he's helped me several times with stuff like this.
The arm is corroded on. Get a can of Kano Aero kroil, spray it on, tap a few times and let it sit. Come back later and it will come right off. What you find inside will need it also. Good luck
Billy K.
Hey BillyK - thanks! You were exactly correct and your solution worked! After I got the arm off - everything else was pretty easy and after a good cleaning/lubrication and tightening - the leak is GONE!
Glad it worked out and you saved $$$$ in repairs.
Billy K.
