I presently have a holding tank under the aft dining settee. I would like to leave it there. Any one know where the LectraSan would go? Maybe on a shelf between the holding tank and the side of the boat.
Jimmy
MarkHubby: I am planning on putting the shelf about 6" above the head outlet thruhull. Do you have vented loops for either water in or head output?
Jimmy
To answer my own question-If the forward Lectrasan is mounted on a shelf between the holding tank and the seatee side support on the port side it will be higher than the electric toilet base and will need a vented loop. An extra 50 bucks and everything works great.
Jimmy
