lets talk vessel documentation
bbruno
I am buying a wellcraft st tropez 32 that is documented. well I have never owned a documented vessel before and need a little input on what I should be aware or concerned. any major costs involved,inspections, any way to check for liens on the vessel or to check ownership beside the document. I have heard it is the way to go from others but want the "experts" advice
the USCG Documentation center will provide info on any liens...
see http://www.uscg.mil/hq/g-m/vdoc/nvdc.htm
they fax it within 24 hours or so and mail the hard copy.
only cost is the one time documentation or transfer fee, no cost for renewals, no inspections...
I believe that the fact that it's documented means there are no leins on the boat. It also means you would have to re-document the boat - the
existing does not carry over. It's useful, but not required, if you take the boat to another country. You will not have to show the state registration numbers - but still have to register and pay taxes. Just don't let someone charge you a couple of hundred bucks to do it. You can DIY for about $50 (not sure what the latest fee is.) Luck. Dale
Documenting a boat is a one time expense. Not sure about transferring a documented boat from one owner to another. Never done that so I'll be interested in the responses to your inquiry.
That's why this is such a great site. We all get educated just by reading.
Consider yourself fortunate it is documented. Last fall, I purchased a boat for use in NY that was in RI but originally delivered to CT and built in NJ. Since this was a large investment, I was very concerned about liens. I hired a documentation company that did the research, got letters from the previous owner(s) and documented the boat. If it was USCG documented, all liens will be in one consolidated database (that's why you are lucky).
Since you are tranferring documentation it is only $84 plus $8 for the CG Bill of Sale. I'm not sure what the lien report costs. In North Carolina, I don't have to register my boat, but in some states even documented vessels have to be registered.
Congratulations on your new boat!
When the boat is sold, the seller is required to surrender the Certificate to the USCG. The buyer then fills out a form for redocumation. Go to the wbe site that Pascal gave you. Its all there.
Frequently documentation is required by lien holders on vessels that qualify for documentation. It is like recording a mortgage for your house only the USCG replaces the Registry of Deeds. If the owner owes money on the boat and the note holder recorded a Preferred Ship Mortgage, its all there. All you need is to request a lien certificate before you pay over the money.
Gene
Though the state can (and most do) require registration of your documented boat, the state cannot issue a title nor require display of state registration numbers (only the annual renewal decal)
"Though the state can (and most do) require registration of your documented boat, the state cannot issue a title nor require display of state registration numbers (only the annual renewal decal)
That is not correct. USCG Documentation has nothing to do with State registration or titleing. A vessel can be USCG Documented and State titled if the state where the boat resides requires it. Boats I have owned were USCG Documented and when the tax was paid to the state I received both state registration and state title although the State Registration Numbers did not need to be displayed, just the "tax" sticker. I have been through this in both NY and MD but the laws vary from state to state so be certain you understand the laws where you will do your primary boating.
If you are not required by a finance company to document the vessel and you have no plans to leave US waters and then return there is really no value in documenting the boat other than it may be more easily traced if stolen.
Finally, if you do choose to document the boat, DO NOT let some outfit charge you $500 or even $200 to do it for you. As stated above, do it yourself for a lot less.
I have to ditto what Mike has stated. My boat is documented witht he USCG, registered in NJ and I received the NJ title papers as well....
I just read something regarding BoatUS making a complaint to the Coast Guard because NJ was requiring title on documented boats and that is NOT what they should be doing. Apparently they can require you to register the vessel (like NY does) but not issue a title as that is what the Coast Guard documentation does.
I think I saw it in this month's magazine issue.
Although there is a mechanism to search for liens on a documented vessel, and a chain of ownership thru a title search, this does not guarantee that there is not a mechanics lien on the vessel. The lien search process only shows recorded liens against the vessel. So as well as the title/lien search, be sure and inquire with local boatyards, and people who have done work on the boat, to be sure that there is no money due. Liens are against a boat--and the workman may not have as much of a leg to stand on, having not recorded a lien, but still worth the search on any boat.
Also the chain of ownership only goes back to the time the vessel was first registered--there could be problems prior to this time. (We once purchased a vessel which had been salvaged in the past, it took a lot of investigation to find this out. If there is a question about the origion of a vessel, this might be the time to employ a good documentation agency. I have documented 6 of my boats, The exception was the one which turned out to have been salvaged--and the extra $500 was money well spent in that case...
Definately a documented vessel is easier to clear in and out of a foreign country, aince customs officials are atuned to the US Coast Guard documentation paperwork. We have cleared into the Mexico and the Bahamas, with state registered vessels with no problems however.
Going along with this thought, in WI if your boat is Documented (like mine) you do not get a Title.
The Cert of Documentation doesn't state a lien holder.
My Wisconsin Boat Registration card (which has to be renewed every 3 years) shows the Documentation Number in place of the WS numbers.
I agree with everything you said. The reason I hired a documentation service was they found and contacted all the previous owners and received letters from them saying to the best of their knowledge, the boat has never had a lien, been salvaged, etc. This was very valuable to me and not something I would have done myself.
I don't believe states can (legally) title a documented vessel. Thus the complaint from Boat U.S.
Funny that you say BoatUS filed that complaint as BoatUS handled all my titling, registration and USCG Documentation work when we bought the boat in NY. We received both the USCG Doc and the NY State title. BTW, BoatUS did all the paperwork FREE OF CHARGE with the exception of the USCG and NY State and notary fees. If BoatUS filed a complaint with NJ they have a bunch of other states they can complain to as well.
Mikee -
I read your posts regularly, and have the utmost respect - but (your recent experience notwithstanding) states cannot legally title a documented vessel. I have researched this issue in the past for my own circumstance. Will do so again (after the holiday) so you don't think I (and Greg above) are shootoing from the hip. Don't like to argue fine points here, but I think this is solidly based in federal law and/or regs.
John,
I'm not disagreeing about what you or others are stating is illegal. I'm only stating what is reality and the current reality in NY, MD and apparently NJ is that they will issue a title for a USCG documented vessel. I'm not one to take up arms when there is little to win and if a state says my USCG documented vessel needs a state title, so be it.. its a no sweat, no cost requirement. Its not worth the fight.
As I said, each state has its on laws (whether a court will eventually rule them valid or not) so as long as the law is on the books you need to work within the law or take-up the fight.
I agree, Mike -- not worth the hassle for us to fight it!
Federal law does trump state law, for certain.
My bet is that some uninformed desk clerk made the decision about your title, supported by an equally ill-informed low or mid level bureaucrat, and that it won't survive legal scrutiny. Happily, we have organizations like BoatUS to explore these issues (as mentioned above), so we can spend our valuable (and all too scarce) free time on the water! Tangled and poorly directed bureaucracies occupy too much of our work time as it is -- hope they can be fended off from the recreation intervals!
Happy Fourth! (must be "your" holiday, judging by the year round avatar?)
John,
You nailed it! The Fourth of July is my favorite holiday. Others can have Santa and all the trimmings; give me BBQs, beer, warm weather, fireworks, Sousa marches and the celebration of freedom. Being a native Philadelphian its only natural for me.
