Livewell
Scatman38
I built a livewell using a 500 gallon pr. hr bassperator kit. The pump is just inside the transom wall and pumps water 10ft to the livewell. The first time it worked purfect. I seem to loose the watter in the line after I shut it off. Almost like an airlock somewhere. I put a loop in the line to stop the water from draining like a peatrap on a sink. I even tried reversing the boat with no sucess. Also tried a check valve on the water side of transom. I put a 750 gal pump on and nothing even after priming the line with water. The pump is running and inpeller fine. Any ideas would be great. Thanks
Is pump mounted below water line, if not is it self priming?
Inlet to live well should be high on the well to keep water from backing out when pump is off.
If you can get a look at a live well at a boating store, you will see what I mean.
Good luck.
