Local Notice to Mariners
NEW YORK – SHINNECOCK B – Construction of the entire
superstructure of the northbound spans of the Robert Moses Causeway at mile 7.3 across Great South Bay is underway. Rigging and installation of Scaffolding will reduce the vertical clearance in the main navigational channel by one foot between May 15 and September 13, and will maintain a minimum of 59 feet vertical clearance between September 14 and May 14. During this period, mariners unable to pass under the reduced vertical clearance through the primary navigational channel should use the alternate route through the State Boat Channel and through the Captree drawbridge mile 30.7. A barge will be operating under the stringer spans through September 30, 2010.Hours of operation are Monday through Friday, 7 a.m. through 3:30 p.m. All
work will be completed by December 31, 2011. Mariners are strongly advised to use the main navigational channel and exercise extreme caution when transiting the area.
Chart 12352 LNM 18/11 (CGD1)
Ok, so if your boat is taller than 59 feet and your in the North Channel, getting under the Robert Moses causeway is the least of your problems!
